Activity › Forums › Adobe After Effects › Learning Expression
Learning Expression
Posted by David Ginting on September 18, 2023 at 4:28 amwhat should i know about before learning expression in after effect? I’m totally have no knowledge of programming language. Please share your tips or trick to learn expression.
Filip Vandueren replied 3 years ago 4 Members · 3 Replies -
John Cuevas
September 18, 2023 at 4:08 pmI don’t know anything about programming either. I bought both of these books(link below) and they are very helpful. If I get stuck, I post questions to the Expression forum, there are some very smart people there. Finally, I keep a document of any good expressions I create or come across.
Ryan Daily
September 18, 2023 at 9:13 pmOne thing you can try is using ChatGPT to build what you want. I was able to have it write me a few expressions that worked well enough. It will even make comments on the code to tell you what each line does.
I know this is not the best way to go about it but it will get you immediate results and you might learn from it. -
Filip Vandueren
September 20, 2023 at 9:50 amI recommend this site and YouTube series:
https://www.animoplex.com/learn/expressions.html#101
animoplex.com
Animoplex - World of Expressions
Master your programming skills with the World of Expressions. Push your creativity to new limits with JavaScript for motion design.
