Activity › Forums › Apple Final Cut Pro Legacy › LCD as Critical Color Monitor
  • Chris Poisson
    August 16, 2006 at 2:01 pm
    Walter,
    What do you mean “the end of CRT production?”
  • Jeff Carpenter
    August 16, 2006 at 2:31 pm
    From what I’ve heard, nobodby makes CRTs anymore.
    They’ve all got warehouses of monitors that were made, boxed, and put on a shelf…you can still buy a new CRT monitor…but I’m pretty sure the factories themselves have all moved on to other products.
  • Walter Biscardi
    August 16, 2006 at 2:39 pm
    [Chris Poisson] “Walter,
    What do you mean “the end of CRT production?””
    Meaning that for environmental reasons (phosphors in the monitors), Sony and Panasonic have ceased professional CRT production. All CRT production is supposed to end by 2009 from what I understand due to the phosphors.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Chris Poisson
    August 16, 2006 at 3:23 pm
    Well I’ll be, did not hear that…
  • Walter Biscardi
    August 16, 2006 at 3:58 pm
    [Chris Poisson] “Well I’ll be, did not hear that…”
    It’s been floating around the web for a while. You’ll see that the Sony PVML5/1 series is now out of stock everywhere which is the monitor I use and recommend to everyone. Right now when the time comes to change, I’m hoping the Panasonic LCDs will get even better.
  • Chris Borjis
    August 16, 2006 at 4:26 pm
    LED backlighting should help things quite a bit after it finally comes out.
    These actually have an off state for black and can produce much higher precision color.
  • Aaron Neitz
    August 16, 2006 at 5:10 pm
    for what it’s worth I was able to tweak an apple cinema display to match a HD-BVM within a gnat’s hair. at least modern LCD’s are capable of getting in the ballpark.
  • David Roth weiss
    August 16, 2006 at 5:37 pm
    [CharlieX2] “for what it’s worth I was able to tweak an apple cinema display to match a HD-BVM within a gnat’s hair. at least modern LCD’s are capable of getting in the ballpark.”
    Charlie,
    Not true. It might appear to you that your apple cinema display is in the ballpark, but as is explained in the article that Walter posted, its not even close.
    DRW
  • Kerry Brown
    August 16, 2006 at 5:57 pm
    Plasmas use phosphors also. No end in site for them?
    KB
  • Kerry Brown
    August 16, 2006 at 6:04 pm
    Check this out. https://www.luminus.com/news/
    KB
