Activity › Forums › Apple Motion › Layers on/off with Rigs
  • Layers on/off with Rigs
    Posted by Univers Becker on September 6, 2012 at 12:31 am
    is there any way I could rig the on an off button of a layer. For Example: I got an animation effect layer like a text layer. With a check box it would be the easiest way to activate and deactivate such an effect.
    thx. univers.
    Mark Spencer replied 14 years ago 3 Members · 2 Replies
  • Anders Larsen
    September 6, 2012 at 1:27 pm
    I don’t know if it can be done with a check box, but you can definately do it with a drop-down menu. Just make two states one with opacity 100% and one with opacity 0% and then use the drop-down to switch between them.
  • Mark Spencer
    September 6, 2012 at 1:32 pm
    You can do it with any kind of widget – the key as Anders pointed out is that you use Opacity to “turn off’ and “turn on” the layer(s).
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
