Activity Forums Apple Final Cut Pro Layering Video
  • Layering Video
    Posted by Andy Milam on July 23, 2012 at 4:26 pm
    I have a projects with many video tracks layered on top of each other.
    I use different blend modes, but mostly just set to add.
    Sometimes the transitions are fine.
    But mostly right at the beginning of a new track of video it cuts in when it should be smooth transition.
    Any thoughts as to why this is happening?
    Andy
    Andy Milam replied 14 years, 2 months ago 3 Members · 4 Replies
  • Loren Risker
    July 23, 2012 at 7:56 pm
    Are you combining your layers into a compound clip, then adding the transition?
    OutOfFocus.TV – Original series, music videos, and entertainment for your couch.
  • Alban Egger
    July 23, 2012 at 8:56 pm
    Andy, I find the way blend-modes and transitions work very inconsistent still. One of the really huge problems in X still.
    it seems to be a problem in the order at which FCPX applies the blend modes.
    You can try to open the video-animation tab (CTRL-V) and fade the clip with the opacity slider. Sometimes that helps.
    Sorry for the bad info 🙁
  • Andy Milam
    July 23, 2012 at 9:39 pm
    Nope, however, I did try making compound clips of all the layered clips with their respective transitions.
    Here is a screen recording of the issure
    https://reels.creativecow.net/film/fxp-x-layering-video-issue.
  • Andy Milam
    July 23, 2012 at 9:40 pm
