Activity Forums Maxon Cinema 4D Layered procedural textures in C4D?
  • Layered procedural textures in C4D?
    Posted by Quba Michalski on March 31, 2009 at 12:40 pm
    Hello,
    I am completely new to Cinema 4D. Until about a week ago I did all my 3D work using Maya, but seeing the fantastic integration between C4D and After Effects, I decided to give it a shot.
    I am currently working on a project where the very long swirl/ribbon gets revealed through animated transparency channel (yes, I know, not the most original thing, but I am just getting started).
    I want the reveal to have a certain degree of organic, random look to it, so I decided to go with a procedural B/W gradient with added turbulence. As the gradient animates from left to right (along the U axis of the UV texture), the geometry gets revealed. Simple enough.
    Now, I want the edges of the geometry to have a fade/falloff effect.
    In Maya I would simply create two gradients and multiply them to create the final texture for transparency. In C4D I cannot figure out how to do that.
    I know it is possible to do layered textures using Body Paint, but the first question BP asks me when I try to do that is the size of the texture. Since my ribbon is very long, I would prefer to keep all the layers procedural and avoid either pixelization or extreme-res textures.
    Here is an image explaining what I am trying to do:
    https://downloads.qubahq.com/C4D_transparency.jpg
    Is it possible?
    Randy Johnson replied 17 years, 5 months ago 2 Members · 2 Replies
  • Quba Michalski
    March 31, 2009 at 5:15 pm
    Hey again.
    In the time it took board moderators to approve my question post, I have already figured out the answer 🙂
    (I am using the “Layer” shader to nest all my procedural gradients together.)
    Quba Michalski
    imago new media studios: http://www.imagonewmedia.com
    Adventures of the Bici Vee: bi.qubahq.com
    Ideas: ideas.qubahq.com
  • Randy Johnson
    March 31, 2009 at 5:18 pm
    In the alpha channel choose LAYER instead of gradiant.Then select the layer then you get the options you are looking for.
    /randy
