Activity Forums Adobe After Effects Layer will not render
  • Layer will not render
    Posted by Rick Symonds on June 17, 2011 at 1:15 am
    I have a layer in an after effects comp that won’t render out. It has rendered in previous passes however I can’t seem to figure out what has changed.
    I basically have a comp that contains footage that is all ProRes422LT and I created a solid layer with a grid effect tweaked to look like scan lines of an old television. The line effect shows up in the preview but when I render the project out…nothing.
    Guide layers are not checked. Any suggestions would be much appreciated.
    Rick
    Bill Williams replied 15 years, 3 months ago 2 Members · 1 Reply
  • Bill Williams
    June 17, 2011 at 2:23 am
    Are the grid lines really small, and you are rendering half res?
    vurb.tv
