Activity › Forums › Adobe After Effects › Layer – Texture matching && Color match.
  • Layer – Texture matching && Color match.
    Posted by Deathwolf on November 6, 2005 at 3:05 am
    I was kinda wondering if anyone knew a plugin/a script already made(else i’m gonna try it myself but it’s a bit messy) to do some sort of tracker that will move a “texture” or “layer” so that it minimizes the difference with the layer under it. Basically you’d give it the approximate initial position and it’d try “compensating” stutters in motion, or any form of movement noise so that the overlay composition gets well.
    Manually searching for the scale/movmeent factors can be very annoying, especially when you want 1/2 pixel precision.
    Another thing i’m wondering about is a way to colormatch 2 pictures that are very similar. There’s an avisynth plugin to do it, but the results are very average, especially compared to some papers-out-there’s results. I’d think there would be a plugin doing that around, but who knows.
    Thanks for any help,
    Paul-Kenji Cahier
    Deathwolf replied 20 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
