Activity Forums Adobe After Effects Layer Styles : Proportionally scale values using percentage
  • Layer Styles : Proportionally scale values using percentage
    Posted by Tom Slinger on November 16, 2020 at 9:53 pm
    Hi there,
    I’m trying to figure out how to change the value of layer styles parameters using a percentage (drop shadow distance, spread and size) (pattern overlay scale).
    For instance, I’d want to change the drop shadow distance from 6 to 3. 100% to 50%.
    Ideally I’d want to be able to use a global control layer to make these percentage adjustments.
    I only want to do this because After Effects doesn’t have a function to automatically scale layer styles like you can do in illustrator.
    @danebberts – any thoughts would be greatly appreciated.
    Tom
    Andy Kiernan replied 5 years, 9 months ago 2 Members · 1 Reply
