Activity Forums Adobe After Effects Layer name – revert to text contents
  • Layer name – revert to text contents
    Posted by Jason Brown on June 1, 2009 at 2:47 pm
    Hey Guys,
    When I revise a text layer (change the characters of the text)…the layer’s name updates to reflect the changes
    However, if I press *return* … and manually change the name of that layer…it always retains that name. Is there a way to revert it back to change the name based on the contents of the text?
    -Jason
    Jason Brown replied 17 years, 3 months ago 2 Members · 5 Replies
  • Dan Ebberts
    June 1, 2009 at 3:48 pm
    Just change the name to an empty string (backspace should do it) and it will again use the actual text as the name.
    Dan
  • Jason Brown
    June 1, 2009 at 4:20 pm
    I’m in CS3 and this didn’t work. Still retains the name I typed in. Any idea why?
  • Jason Brown
    June 1, 2009 at 4:23 pm
    Hey Dave,
    I didn’t see where this link had any information about what I was asking. Dan’s suggestion didn’t work for me in CS3.
    Additionally, I like having the manual online…but I’ve used CS4 at a friend’s shop, and I don’t like HAVING to go online to get to the manual. Is there an option to have it on your machine locally as well?
    -Jason
  • Dan Ebberts
    June 1, 2009 at 5:03 pm
    I just tried it on CS3. Select layer, hit Enter, hit Backspace, Hit Enter. That doesn’t work for you?
    Dan
  • Jason Brown
    June 1, 2009 at 5:51 pm
    I’m sorry Dan, it did work. I was trying to go into the text and delete the text information…not delete the name information.
    This helps…thanks so much!
