Activity › Forums › Zaxwerks › Layer Mapping Problem
  • Layer Mapping Problem
    Posted by Subspecies on April 29, 2005 at 5:30 pm
    hi all,
    i’m trying to put a logo onto a rotating sphere.
    so for example i have a sphere that i’ve extruded in Invigorator, then want to layer map my logo on the front and back of the sphere.
    pretty simple.
    my problem is that when my logo is mapped onto the sphere it becomes bitmapped (almost looks low quality, even though all my switches are set to full quality)
    my logo is an .eps that is NOT rasterized.
    i don’t understand why i can’t geta clean, crisp layer map.
    help???
    Matt Rhodes replied 21 years, 5 months ago 2 Members · 1 Reply
  • Matt Rhodes
    April 29, 2005 at 6:07 pm
    Hi Dante.
    I’m assuming that you imported your logo as an EPS into After Effects and
    that you added it to a Comp as a layer. You are then using that layer as a Layer Map
    in the Invigorator. Correct?
    Here’s how the Invigorator handles this situation:
    – When you add the logo as a layer to a Comp, it gets rasterized to a certain size in the Comp.
    – When the Invigorator grabs the logo image, it gets the rasterized image of your logo.
    – Therefore, if your Comp is 640×480 and your logo layer is scaled to be the same size as the Comp
    window, the Invigorator will use the logo as if it’s a 640×480 image.
    To make your logo larger in the Invigorator, make your logo layer as large as you’d like it to be,
    even if it ends up larger than the Comp window. The Invigorator will get the entire layer.
    Let me know if you need more assistance.
    Matt Rhodes
    Zaxwerks, Inc.
