Activity › Forums › Zaxwerks › Layer Mapping Distortion
  • Layer Mapping Distortion
    Posted by Joel Slabaugh on June 22, 2010 at 10:37 pm
    Hi all,
    I’m trying to make a layer map of a precomp pull back from full frame into an animation. I have my plane set up in invigorator to be the same aspect ratio as my comp frame. The layer map is set using absolute color to avoid color shifts.
    When i adjust the camera so that the layer mapped plane fills the whole frame it creates a slight distortion in the image when i compare it to a regular after effects layer of the same image. No matter how finely i adjust the camera there is distortion happening. I’m talking very slight distortion but i’m still curious if there is a way to get rid of it.
    I’d really like to have a layer mapped image in invigorator that appears exactly the same as a layer in the comp. I’m guessing this is a render anomaly with invigorator that probably won’t allow it to have a 1 to 1, pixel for pixel image that matches with the after effects renderer.
    Any thoughts would be appreciated. Thanks!
    Serge Hamad replied 16 years, 3 months ago 3 Members · 3 Replies
