Activity Forums Adobe After Effects layer light
  • layer light
    Posted by Ali Dastnama on January 22, 2015 at 3:04 am
    Hi . sorry if i cant speake very well english .
    i have problem with layer light , i can choose that but i can’t see the shadow , i can move the light , change the valu , but i can’t see any changed, tanks
    John Cuevas replied 11 years, 8 months ago 2 Members · 1 Reply
  • John Cuevas
    January 22, 2015 at 12:46 pm
    Select the light and press quickly “AA” to open the light options and make sure “cast shadows” is on. Click the layer you want to cast shadows, it has to have have 3D enabled, then press “AA” quickly to open the material options and make sure “cast shadows” is on. Finally select the shadow catcher layer, enable 3D and press “aa” quickly to make sure accept shadows is on.
    I made a simple project, so you can see the setup.
    8425_castshadows.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
