Activity Forums Adobe After Effects Layer emitter, trapcode particular
  • Layer emitter, trapcode particular
    Posted by Ray Bryant on June 11, 2017 at 7:11 pm
    I was trying to do a simple particle effect where the particles form a logo, here is the video I used as a tutorial, https://www.youtube.com/watch?v=yCRm_50vAJA&t=215s
    For whatever reason it refuses to work. Everything goes fine until I set the emitter from point to layer (3:22 in the video) , when I try to select the layer from which to emit the particles nothing happens. I checked all of the settings a dozen times, reinstalled and uninstalled Trapcode, cleared cache, played with the seed, and tried different layers in different files. I can probably send the file over E-mail if necessary.
    Ray Bryant replied 9 years, 3 months ago 2 Members · 4 Replies
  • Greg Gesch
    June 11, 2017 at 11:38 pm
    Hi Ray, I suspect you probably need to set the birth rate extremely/ridiculously high – it emits from the whole layer including the alpha.
  • Ray Bryant
    June 12, 2017 at 12:57 am
    So would that be the particles/second? I have that set to 25000 and I’m still not seeing any particles.
    Hey Sailor!
  • Greg Gesch
    June 12, 2017 at 1:42 am
    Have a try at more – he suggests 300.000!
  • Ray Bryant
    June 12, 2017 at 2:11 am
    Yeah still nothing. And I mean no particles being generated at all, not invisible ones or anything like that because my pre render is too fast for there to be any particles, certainly not 300,000.
    Hey Sailor!
