Activity Forums Adobe After Effects Layer Control to drive opacity of a single layer
  • Layer Control to drive opacity of a single layer
    Posted by Craig Kristensen on April 28, 2016 at 8:38 am
    I have a comp with hundreds of layers (all with an opacity of 0), and I need an easy way to select just one layer and make it visible.
    Is this possible with “Layer Control”? Possibly in combination with a Check box that sets the opacity value to 100 when checked?
    Craig
    Wallace Adrian d’alessio replied 10 years, 4 months ago 3 Members · 5 Replies
  • Craig Kristensen
    April 28, 2016 at 9:11 am
    I have been trying to get something like this to work.
    I have a text layer that reads the value of the Layer Control using:
    thisComp.layer(“— SELECT”).effect(“Selector”)(“Layer”).name
    And then using this on the opacity for each layer to check if the “FRANCHISE NAME” equals the name of the layer. If so, “then opacity = 100”
    ifi(thisComp.layer(“FRANCHISE NAME”).text.sourceText = (“thisLayer.name”)) 100 else 0;
    But I’m having some syntax troubles.
  • Walter Soyka
    April 28, 2016 at 9:53 am
    [Craig Kristensen] “I have a text layer that reads the value of the Layer Control using:”
    Layer Controls cannot be keyframed, so this value will be constant throughout the comp. It doesn’t sound like that’s what you want.
    [Craig Kristensen] “ifi(thisComp.layer(“FRANCHISE NAME”).text.sourceText = (“thisLayer.name”)) 100 else 0;
    Here’s the correct syntax:
    if (thisComp.layer("FRANCHISE NAME").text.sourceText == thisLayer.name) 100 else 0;
    1) It’s “if” not “ifi”.
    2) Equality comparison uses “==” not “=”.
    3) There is no reason to enclose thisLayer.name in quotes and parentheses. “name” is an attribute of the object called “thisLayer”.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Craig Kristensen
    April 28, 2016 at 10:02 am
    Works perfectly!
    Is it possible to use a Layer Control to select layers in a different comp?
  • Walter Soyka
    April 28, 2016 at 10:19 am
    [Craig Kristensen] “Is it possible to use a Layer Control to select layers in a different comp?”
    No, but you could refer from your main comp to a layer control effect on a layer in a different composition:
    comp("OTHER COMP").layer("— SELECT").effect("Selector")("Layer").name
    Walter Soyka
  • Wallace Adrian d’alessio
    April 29, 2016 at 3:21 pm
    You can precomp . Then drag out timelines for the precomp and the comp and then pick whip across.
    I have done it.
    Adrian D\’Alessio aka; Fluxstringer
    fluxstringer@gmail.com
    https://www.facebook.com/FluxStringer
    https://www.linkedin.com/in/fluxstreamcommunications
    https://twitter.com/FluxStringer
    https://mog.com/FluxMuse
