Activity Forums Maxon Cinema 4D Layer Access Node in Xpresso
  • Layer Access Node in Xpresso
    Posted by Todd Meinhoff on November 9, 2021 at 1:10 pm
    Hey Everybody,
    Just working on a project and need to quickly toggle different combinations of layer’s visibility, generators, and deformers. I’ve found a useful script called “Layer Access” by Nikolas Rosenstein. It does exactly what I need it to do, but when I follow this tutorial: https://vimeo.com/72092919 It’s not functioning. Currently the Node turns yellow when linking or selecting the layer. Unsure if ifs a compatibility issue as I’m using r25 and the script is 8 years old.
    Anyone have any ideas on what’s going on here. Anyone have any idea what’s going on or where I can start trying to correct any errors? Here is a link to the node file: http://www.mattfrodsham.com/s/LayerAccess_NiklasRosenstein.c4d
    Thanks for any tips!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Todd Meinhoff replied 4 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
