Activity Forums Audio Lavalier Mic with portable recorder?
  • Lavalier Mic with portable recorder?
    Posted by Eric Marx on December 10, 2007 at 7:27 pm
    I have an iriver ifp-799 and want to use it with a lavalier mic since it has a 1/8″ mic input (not just line).
    Can anyone tell me whether a Countryman EMW with a 1/8″ (3.5mm) connector will work with this? The EMW seems to be designed for wireless systems.
    If not, are there any other high-end lav mics you could recommend that would work for recording conversations in noisy environments?
    Eric
  • Bouncing Account needs new email address
    December 12, 2007 at 4:54 pm
    The Countryman (and most other pro-level mics, condenser-types) require battery power (1 volt, or so) to operate.
    Wireless transmitters provide that power on their inputs.
    A portable recorder (iRiver, in this case) will likely NOT provide this, unless it specifically says so.
