Activity Forums Zaxwerks Lathe object artifacting
  • Lathe object artifacting
    Posted by Liam Stirland on October 28, 2013 at 9:50 am
    I am creating a custom lathe object by creating a circle, converting it to a lathe object then reducing the build angles to create a sort of 1/4 doughnut shape, All works fine apart from the ends of the custom lathe shape have huge ‘spikes’ extruding from them.
    Any ideas?
    Jeremy Silverthorn replied 12 years, 10 months ago 3 Members · 2 Replies
  • Edward Wu
    October 30, 2013 at 11:27 pm
    Hi Liam,
    Please check your email. I have sent you a revised version of the model. If you have any other problems with the models, please let me know and I’ll do my best to assist you.
    Best,
    Edward
  • Jeremy Silverthorn
    November 22, 2013 at 6:57 pm
    I’m having a similar issue myself… I have a simple outline created in illustrator and converted to a lathe object in ProAnimator… a pan. It looks great when the build angle is a complete 360, however when I change it to just make a pie shaped piece of my object (or remove a pie-shaped slice of the object), I get these crazy artifacts on the ends. I have tried a couple changes with the path in the illustrator file, however it has only given me a different artifact, not eliminated it. Any ideas??
