Activity Forums Apple Final Cut Pro Legacy Lateral jitter in FCP from AFX movie
  • Lateral jitter in FCP from AFX movie
    Posted by Craig Spoth on August 22, 2005 at 8:48 pm
    i have this chronic problem where vertical lines (like the sides of a rectangle) made to move laterally (left to right or vice versa) across the screen in after effects, look jittery when i bring the movie into Final Cut. I’ve tried both the DV/DVC codec and the animation codec from aftereffects, but there seems to be no difference. Motion blur doesn’t help the problem either. i hope someone can help.
    Craigers
    In time, whats deserved always gets served. -COC
    Craig Spoth replied 21 years ago 2 Members · 2 Replies
  • Bret Williams
    August 22, 2005 at 10:52 pm
    Are you field rendering in the right order?
  • Craig Spoth
    August 26, 2005 at 2:02 pm
    i’ve tried both upper and lower fields first. Both made it look worse than when i had no field designation. What the hell am i missing here?
    Craigers
