Activity Forums Apple Final Cut Pro Legacy lateral bars on youtube export
  • lateral bars on youtube export
    Posted by Gabriele Gismondi on May 16, 2010 at 9:36 am
    hi,
    i’m coming out from FC with a 1280x720p ProRes Mov, then i drop it nto Mpgstreamclip to get a H264 (same 1280×720, no scaling) to put on Youtube/vimeo channels. it looks great, only fact it gets in the “windows” with two little black bars on left/right..can’t get the problem fixed..may be there a ratio problem somewhere? tnx
    Joseph Holder replied 16 years, 4 months ago 2 Members · 3 Replies
  • Joseph Holder
    May 16, 2010 at 3:46 pm
    what are your dimensions? from your camera? and when you export, and also on youtube, this may help you can put this in the tags, that crops or stretches it type yt:crop=16:9 or yt:stretch=16:9 and it should look ok
  • Gabriele Gismondi
    May 16, 2010 at 3:53 pm
    tnx..i come out 1280×720, export 1280×720 and the h264 kept at 1280×720..so i should put in the yt TAGS “yt:stretch=16:9 “?
  • Joseph Holder
    May 16, 2010 at 5:40 pm
    yes, that would help unless you are filming with a square aspect ratio on the camera (4:3) then you should crop
