Activity › Forums › Apple Final Cut Pro Legacy › Last gen MBP vs. 13″ unibody MBP
  • Last gen MBP vs. 13″ unibody MBP
    Posted by Patrick Simpson on October 6, 2010 at 4:39 pm
    I’m on a serious budget and I’m looking at a couple different possible Macbook Pros.
    First, is a pre-unibody 15″ MBP (early 2008 model), 2.5 GHz Core 2 Duo, max of 4GB ram, and the Nvidia 8600M GT w/ 512 MB vram.
    The other would be a 2009 13″ unibody MBP with a 2.5 Core 2 Duo, max of 8GB ram, and the Nvidia GeForce 320M chip w/ 256mb shared memory. Or,
    a 2010 unibody 13″ MBP with a 2.4 GHz Core 2 Duo, max of 8GB ram, and the Nvidia GeForce 9400M chip w/ 256mb shared memory.
    As best as I can tell, applications like Motion (or 3D-heavy games) rely on the GPU and HD editing in FCP relies primarily on the CPU (and ram and hard drive speed, of course). So, the 13″ unibody MBPs should provide comparable performance to the older 15″, right? It’s worth noting that the newer MBPs have faster ram (DDR3 vs. DDR2).
    What would you all opt for? Am I missing anything?
    Andrew Evans replied 15 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • Paul Dickin
    October 6, 2010 at 4:52 pm
    Hi
    I chose an older 15″ MBP because of the ExpressCard slot to run eSATA drives – FCP is better with the faster drive access.
    I got AppleCare because there has been a history of graphics card failures in the older 2007-8 MBPs:
    https://support.apple.com/kb/ts2377
  • Jerry Hofmann
    October 6, 2010 at 4:58 pm
    Yeah, you’re possibly missing 3 things.
    1. Expandability. There’s no way to run an external monitor inexpensively (Io HD will work and they run 3k) without an express card slot.( Matrox MXO might work, but I’d check it out before I committed to a Mac of any ilk, as it uses the second monitor port to do it’s trick) There’s also only one FW bus in any Mac, so you can’t add another without the card slot. Firewire cameras and firewire drives really work a lot better on machines with two busses) AND you can’t add a USB 3 card, nor an eSATA card to anything you’re looking at, so you’ll always be constrained to slow external disk drives.
    2. Color won’t run on the 13″… so you lose a fabulous color application by buying one. It will open maybe, but the display is just too low a res to show the app properly)
    3. The only “lately” made MBP’s with a card slot are the 17″ machines.
    So depending on what you want to use the Mac for, and what your acquisition and delivery mechanisms/formats are going to be, you might not want to buy less than a 17″ machine… a used one sells for not much more than it’s 15″ counterpart. Even the current 17″ has the express card slot.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Patrick Simpson
    October 6, 2010 at 5:09 pm
    Some great thoughts.
    I probably won’t be monitoring because my primary delivery right now is web. But having the expresscard slot for esata sure would be nice, otherwise I’m editing w/ a FW800 drive.
    Most of my acquisition will be solid state from a DSLR, so having multiple FW buses isn’t crucial. Then again, it’s always nice to have the option for expandability w/ the expresscard slot.
  • Bob O’brien
    October 8, 2010 at 11:44 am
    Also, assuming you’re planning to use FCP on a 13″ – no thank you.
    CAMERAS
    Sony EX3 & Sony DXC637/PVV3 Betacam-SP
    PORTABLE EDITING
    *MacBook Pro – 2.33Ghz – 2Gb RAM
    *Matrox MXO / 23″ Cinema Display
    DESKTOP
    *DualG5 2Ghz w/2.5Gb RAM
    *UL4D SCSI Card
    *HMV800 DualMax RAID0
    *AJA IO
    *Sony 2800
    SOFTWARE
    *OSX10.4.11, QT 7.5, FCP 6.0.4, Livetype 2.1.3, Soundtrack Pro 2.0.2, DVDSP4.2.1, Adobe CS3 Prod Suite
  • Andrew Evans
    October 10, 2010 at 2:30 am
    haha i do it and its not great. but i do have a cinema display that i hook up to when I’m at the office.
  • Patrick Simpson
    October 10, 2010 at 2:36 am
    Andrew, you’re saying you edit on a 13″ macbook pro? What are the specs? Other than screen size, what are some issues or hangups you’ve run into? Do tell!
    We’ve heard from a lot of people raising a stink over the idea of editing on a 13″ macbook pro, but not many who actually do it (and have lived to tell about it).
  • Andrew Evans
    October 10, 2010 at 3:26 am
    …”and live to tell about it.” haha. true true.
    mine is the 2.4ghz 4gb of ram. i did put a 320gb 7200 hard drive in it and that made it a bit faster. not that i edit off the internal. i have a g-raid fw800.
    I really don’t mind editing on it. I have a usb keyboard, mouse and 23″ display attached to it. bigger display is a must. other than that it works fine for FCP and AE. its just slower rendering.
    The only reason i have this is for portability. If you don’t need a notebook you might look into getting an earlier macpro (1,1 or 2,1). I think they go for around $1,500 on ebay.
    andrew
