Activity › Forums › Adobe Premiere Pro › Last audio hangs
  • Last audio hangs
    Posted by Dorian Weber on May 3, 2018 at 12:01 pm
    I found a solution:
    just add an empty audio file at the end.
    Thank you
    Dorian
    Hello,
    I never really worked with audio but this time I make a slideshow and I have a few video clips which have some audio. Strange enough, the last bit of audio keeps on repeating over and over again. Until I have an other audio clip. And then the last bit keeps on repeating over and over again.
    On the original timeline I can not find anything wrong, but after I export and transcode it to H.264 it shows.
    I really need that slideshow working.
    Thank you in Advance
    Dorian
    Dorian Weber replied 8 years, 5 months ago 2 Members · 2 Replies
  • Jon Doughtie
    May 3, 2018 at 3:13 pm
    BTW, sometimes compressed audio (for example, MP3) will misbehave in the timeline. I almost always convert to uncompressed audio for the edit.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Dorian Weber
    May 3, 2018 at 3:52 pm
    thank you for telling me!
    Because the main audio will be MP3 music.
    I would appreciate it if you could give me some advice on how and where to change it. I still have Soundtrack Pro.
    And if you could give me some settings would be also great since I never worked with audio before.
    And this video is very important to me.
    Dorian
