Activity Forums Adobe After Effects Lasso animation
  • Lasso animation
    Posted by Christophe De backer on February 10, 2012 at 3:53 pm
    Hi all
    I’m trying to make a little background animation in AE where there is a character that runs with a lasso in his hand. Character is running and everything. That was quite simple.
    Basically I wanted him to do this:
    https://www.animationlibrary.com/animation/28490/Boy_with_rope_2/
    It was some fun little idea I had when working on a project but for some strange reason I didn’t get it to work.
    Rotation is all wrong, linking/parent the knot to the rope didn’t work. I tried with time remapping the frames from the animation.
    So I left it out, but now I’m wondering what I forgot to do.
    Any tips?
    Christophe from Belgium
    Christophe De backer replied 14 years, 6 months ago 3 Members · 6 Replies
  • Roland R. kahlenberg
    February 11, 2012 at 12:38 am
    The Beam effect coupled with some displacement should be decent for the rope. To have one end of the rope attached to the circle, an Expression to link the End Position of the Beam effect to a Null’s Position Property should work. BUT first, copy and paste the circle’s Mask Path property to the Null’s Position.
    You can KF the Mask Path and then copy its KFs to the Null’s Position to get a more interesting effect. There is no need to rotate the circle. A Ramp and/or animated Vegas effect should help to provide the illusion that the circle is rotating.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Tudor “ted” jelescu
    February 11, 2012 at 9:52 pm
    Or you can try Plexus – if you use Lights as points, you can get a line to move in 3d space between the two Lights/Points, Link and position one light to the character running, link a Null to this Light, position it as the center of the lasso loop and link the second Light to it, positioning to be on a circle (either a 2d layer with a circle graphic positioned in 3d space, or use Particular on a different layer using the same Light as a generator together with the “ipod streak” technique to create a true volumetric 3d loop). If you rotate the loop centered Null on it’s y axis you should get what you need (add a x or z axis variation to simulate the wobble)
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Christophe De backer
    February 12, 2012 at 10:40 am
    I was experiencing with the beam effect, but forgot the Null.
    Thanks! If you don’t use AE for 11 months you tend to forget the basic things.
    February 12, 2012 at 10:43 am
    Hmm, I don’t own Plexus. And the “ipod streak” technique no idea what that is.
    thanks for the info.
    February 12, 2012 at 8:09 pm
    Plexus – worth buying the plugin!
    Light streak:
    https://library.creativecow.net/articles/kramer_andrew/nano.php
    Tudor “Ted” Jelescu
    Senior VFX Artist
    February 15, 2012 at 3:17 pm
    Indeed, Plexus looks great. Maybe for a next project.
    I succeeded. Thanks!
