Activity Forums VEGAS Pro Lag when ALT+TAB’ing from other windows to Vegas 12 Pro
  • Lag when ALT+TAB’ing from other windows to Vegas 12 Pro
    Posted by Vincent Levalois on December 8, 2012 at 6:37 pm
    I switch between windows a lot when editing, gathering clips, sounds, etc. from other folders. I use ALT+TAB a lot and I always have this issue when going back to Vegas, there’s a good 3-5 second delay before the hourglass goes away and the location marker is available again. Anyone know why this is or how to make things more immediate?
    John Rofrano replied 12 years, 4 months ago 4 Members · 6 Replies
  • John Rofrano
    December 8, 2012 at 7:18 pm
    [Vincent Levalois] “Anyone know why this is or how to make things more immediate?”
    Yes, this is happening because Vegas releases the open file handles on all media so that you can edit them in another program (which is one reason why you might Alt+Tab away from Vegas Pro). When you come back, it then has to reopen all the media to pick up any changes.
    If you don’t want this behavior you can disable it by going to Options | Preferences | General and uncheck “Close media files when not the active application” and Vegas Pro will keep a handle on the media files.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Vincent Levalois
    December 8, 2012 at 7:21 pm
    Excellent, thank you very much for the response and the solution. I rarely edit outside of the app, but I’ll be aware of this from now on.
    Thanks again!
  • Aleksey Tarasov
    December 8, 2012 at 7:22 pm
    Go to Options > Preferences and switch off “Close media files when no the active application” option
    Vegasaur.com – Plugins for Sony Vegas Pro
  • John Rofrano
    December 8, 2012 at 8:16 pm
    You’re welcome. Glad I could help.
    ~jr
  • Lutchi Gee
    April 14, 2014 at 3:39 pm
    OMG thank you so much. this annoyed me for YEARS !
    it should have some warn or something to let user aware of this.. maybe when it comes back to focus, some popup or some floating box saying “reopening the files. change this behavior in blablaba….”
    thanks again !
  • John Rofrano
    April 14, 2014 at 8:22 pm
    Glad it helped you out. 😉
    ~jr
