Activity Forums VEGAS Pro Lag between clips
  • Lag between clips
    Posted by Collin Howe on September 14, 2008 at 6:31 pm
    I’m making an AMV and at times it lags when switching between different clips. It lags for about 2 seconds, then starts running through the clip normally. How do I eliminate this lag gap?
    Collin Howe replied 17 years, 11 months ago 2 Members · 6 Replies
  • Laszlo Kovacs
    September 15, 2008 at 6:40 pm
    Pleas forgive me if my question is stupid…
    What’s an AMV?
    Regards
    K.L.
    Kovácsolt Videó
  • Collin Howe
    September 15, 2008 at 10:51 pm
    An AMV is an “Anime Music Video.” They’re typically made by syncing music with various clips from an anime series.
  • Laszlo Kovacs
    September 16, 2008 at 5:56 am
    I see.
    Could you be some specific about your workflow?
    Where do you get those lags?
    (timeline/rendered video?)
    Regards
    K.L.
    Kovácsolt Videó
  • Collin Howe
    September 16, 2008 at 11:15 pm
    The lag becomes increasingly worse as the video progresses (the clip transition lag). At first there’s NO lag between the clips (for 1 transition) then the lag gradually worsens to about 3-4 seconds of hiccups and lagging. After the laggy transition, however, the clip runs perfectly fine. That is, until the next clip transition.
    I think
    -hidden “gaps” may have developed during the video assembly and accumulated; thus worsening it progressively
    -Video type simply doesn’t get along with Vegas (I downloaded it directly from VeohTV)
    -I tinkered around with the VeohTv footage on Windows Movie Maker, and discovered the same problems, however I found that only specific clips produced that problem.
    -Didn’t see a gradual compilation of lag that time.
    I’m still not exactly sure as to what’s going on. Is there some sort of “feature” on Vegas that compensates for that lag?
  • Laszlo Kovacs
    September 17, 2008 at 4:00 am
    I still don’t really understand where that lag could come from, so I decided to look for veohtv you mentioned.
    I hoped I find there something, anything, that makes me understand.
    Unfortunately veohtv is blocked, I can’t access it just because being in Hungary.
    I’ve necer seen such a discrimination on the internet so far.
    Regards
    K.L.
    Kovácsolt Videó
  • Collin Howe
    September 17, 2008 at 10:54 am
    Wow. I can’t believe they blocked you =/.
    I should be fine though. I was tinkering around with it last night and I think the Veoh clips are what’s causing the problem.
