Activity Forums Apple Final Cut Pro Legacy Lacking moving image in FCP
  • Lacking moving image in FCP
    Posted by Søren Rye on February 17, 2010 at 11:03 am
    Hi
    I have a huge problem, that I hope some of you can help me with.
    Let me try to explain it correctly:
    I have shot some videofootage with Canon 5d Mark II. I have used the motion tab in FCP, to have the whole video image moving across the screen. That is easy to do, but:
    When I export it, there are huge stripes as soon as the image starts to move (looks like it’s a problem with interlacing), and it is also really lacky.
    Is it the motion tab in FCP there are unusable, or is it the technical specifications of the video?
    I have converted the raw footage (before editing) to Apple Proress 422, and tried with both 24, 25 29.27 fps, and exported the final edit as Quicktime Movie.
    What can be wrong? Should I use another plugin to do the “image-moving-thing”, or is it the specs of the footage?
    I hope you can help me, and just let me know, if you want me to explain it in another way.
    Regards
    Søren Rye
    Søren Rye replied 16 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
