Activity Forums VEGAS Pro l recorded with very low volume….
  • l recorded with very low volume….
    Posted by Daniel Valencia on February 20, 2011 at 10:26 pm
    hey there
    l recorded a video of a wedding with a very low volume set. (my fault) almost nothing can be heard. You can hear a little but the volume has to be set all the way up. l need to add other soundtracks to the video. l imagine will be a jump in and out of sound because of it.
    Is there a way to improve the sound form the original footage??
    thank you
    Nigel O’neill replied 15 years, 7 months ago 4 Members · 5 Replies
  • John Rofrano
    February 21, 2011 at 12:24 am
    [daniel valencia] “Is there a way to improve the sound form the original footage??”
    Right-click the audio event and select Switches | Normalize. That should bring up the volume considerably if it’s very low.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    February 21, 2011 at 1:37 am
    Also, check out the free program “Levelator”.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Nigel O’neill
    February 21, 2011 at 2:48 am
    You could also boost the sound using the graphic equaliser plug-in by up to 20db… . I recently had to do this when my sound feed from the sound desk was just a hiss and I had to rely on camera mic audio only.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Daniel Valencia
    February 21, 2011 at 3:55 am
    @ niegel ; how do i get that plugged in my friend.
  • Nigel O’neill
    February 21, 2011 at 11:26 am
    I assume you are using SVP9:
    Right click the event audio wave form you are trying to improve.
    Select Apply non-real time event FX
    Choose Audio > Sony > ExpressFX Graphic EQ or Graphic EQ
    Have a play around, noting that there is also an output gain slider. Experiment.
    If you are using SVP10, this is available in real-time.
    You can do it at track level as well, but it affects the whole track. In my case, I only needed it for certain video events.
