Activity Forums Adobe Premiere Pro Kramer FC20
  • Kramer FC20
    Posted by Michael Spencer on April 10, 2007 at 4:15 am
    Anyone have any advise on these? I am needing to output SDI from PP2. Canopus ADV1000 is a lot more $$.
    Is PP2 compatible with the Kramer? Any other good DV-SDI SDI-DV converters.
    Jean Coulombe replied 19 years, 5 months ago 3 Members · 2 Replies
  • Tim Kolb
    April 10, 2007 at 5:46 pm
    The Convergent Design SD Connect is an excellent and flexible converter.
    https://www.convergent-design.com/
    It isn’t inexpensive, but for all that it offers, it’s a good value. It has been a good machine for me anyway…
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Jean Coulombe
    April 11, 2007 at 2:02 am
    Yes the kramer is copatible with premiere but last fall a had 3 unit sent back and fort
    and they could not fix a problem of chifting the video frame 2 to 3 line down from sdi
    to dv so we whent with the sd connect and it is perfect the only problem is the sdi output
    of the sd connect, the embeded audio is making my digibeta audio input selector flash
    meaning there are no signal present but the audio is still passing but i don’t
    trust it the solution for now is to used the sd connect aes audio output to the
    digibeta a future firmware update will fix that we have also the hd connect-mi
    and it also had this problem with sdi embeded audio that got fix with a firmware update
