Activity › Forums › AJA Video Systems › KonaLS, OSX 10.3.9 and Quicktime 7.0.3 ?
  • KonaLS, OSX 10.3.9 and Quicktime 7.0.3 ?
    Posted by Christopher Tay on January 12, 2006 at 1:05 am
    I’ve got a Kona LS system currently still running on OSX 10.3.9 with Quicktime 6.5.2. This was upgraded from a Cinewave system so Quicktime was still left at that version.
    Now with KonaLS, is it safe to update Quicktime to 7.0.3 but still remaining on OSX 10.3.9 ?
    -chrispy
    Christopher Tay replied 20 years, 8 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    January 13, 2006 at 1:02 am
    I’d not do that. If it’s not broken, don’t fix it. BUT I’d upgrade to Tiger in a heartbeat, then QT 7 is the only way to go there.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Christopher Tay
    January 13, 2006 at 7:45 am
    Hi Jerry,
    Hope you’re doing fine.
    I’ve checked with AJA and they reckon it should be ok. I’m running FinalTouch on this system as well and we suspect it might be the QT version as it refuse to launch but on OSX 10.4.3 it lauches ok.
    I’ll give it a shot first and if somethings goes wrong, I can always revert back to 6.5.2 as there are QT reinstallers available to downgrade from 7.0.3 all the way back to 6.5.2.
    -chrispy
