Activity › Forums › AJA Video Systems › Konal LHe:out 2 components
Posted by Tommaso Cicognani on March 23, 2009 at 9:11 amhi all,
is it possible to run 2 monitor (1 plasma full hd(client view) + 1 crt SD(CC))simultaneously in component from my aja kona LHe?Gary Adcock replied 17 years, 6 months ago 3 Members · 4 Replies -
Gary Adcock
March 23, 2009 at 12:07 pm[tommaso cico] “is it possible to run 2 monitor (1 plasma full hd(client view) + 1 crt SD(CC))simultaneously in component from my aja kona LHe? “
no not unless you pass the signal from one display to another,
no AJA board offers 2 component out signals, as the movement is to all digital displays.you can use an AJA HD10MD3 to Downconvert the signal to component or AJA HD10HC2 for D > A as component from either one of the HD/SDI outputs on you LHe.
gary adcock
Studio37
HD & Film Consultation
Post and Production WorkflowsInside look at the IoHD
https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php -
Walter Biscardi
March 23, 2009 at 12:14 pm[tommaso cico] “hi all,
is it possible to run 2 monitor (1 plasma full hd(client view) + 1 crt SD(CC))simultaneously in component from my aja kona LHe? “As Gary says, you can feed to monitors via Component using a loop through, like we do here, but it’s all the same signal. We loop component through our Sony CRT to the Plasma.
The converter Gary recommends will work nicely or you can get the AJA Hi5 I believe it’s called to convert HD-SDI to HDMI which comes standard on the Panny plasmas these days.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Tommaso Cicognani
March 23, 2009 at 12:50 pmWorking in HD:
with the aja hi5 can I have simultaneously hd-image on the plasma and a downconverted image on my crt?I think it is not possible unless I buy an external downconverter to feed my cd crt monitor.
is it right what I assumed? -
Gary Adcock
March 23, 2009 at 1:31 pm[tommaso cico] “with the aja hi5 can I have simultaneously hd-image on the plasma and a downconverted image on my crt?”
no
but it would allow to send one of the HDSDI signals > HDMI > to plasma and then use the component for the SD signal.
gary adcock
Studio37
