Activity › Forums › AJA Video Systems › KONA/FCP layoff problems
  • KONA/FCP layoff problems
    Posted by Mark Spano on June 10, 2010 at 10:11 pm
    I’ve been having a very frustrating problem and I wonder if anyone here has experienced it and maybe solved it. I have two stations, both connected to XSan over fibre. These stations have the following specs:
    Quad 2.5GHz PPC G5
    4.5 GB RAM
    Mac OS 10.4.11
    AJA KONA LHe (ver. 6.0.3)
    FCP 6.0.6
    Dual 3GHz Intel Xeon
    3 GB RAM
    Mac OS 10.5.8
    AJA KONA 3 (ver. 6.5)
    FCP 6.0.6
    Each card is locked to house ref, as are all of the output decks. I am experiencing the same intermittent problem on both systems when trying to edit sequences to tape. I go to lay off and the machine (DVW-A500 or SRW-5500) goes in at the correct in-point. However, upon checking the edit back using the jog at the machine, I see that there is one duplicated frame at the in-point, followed by my sequence as it should have played. Basically what I have on tape is this: if my sequence (for example) is 5 frames long and the frames can be labeled ABCDE, then on tape I get AABCDE. So on a countdown, for example, the 10 goes in correctly at 00:59:50:00, but every number after that shows up at 00:59:51:01, 00:59:52:01, etc. including my spot, starting at 01:00:00:01. This plays out without dropping frames and I get a perfect result *except* for the first duplicated frame, which offsets the whole thing on tape. If I go to perform the same edit again using the same exact in points, sometimes it will just land correctly and not throw in that duplicated frame.
    The fact that it’s happening on both systems leads me to believe that whatever they’re sharing is likely the culprit (i.e., the XSan). I ran the AJA system test utility to see if there was a bandwidth breakdown, but it seemed like it came back OK. Results on a single 1920×1080, 10-bit uncompressed file below:
    I also did a “Frame Size Sweep” to give it a chance to cover all types and graph out a performance chart for my XSan. Here’s that:
    So yeah, I’m at a loss. The fact that it keeps putting out this duplicated frame is making me crazy. I have tried exporting the sequences to self-contained QT and re-importing them to a new project straight to the viewer and editing to tape from there – same intermittent success. Anybody ever seen this happening?
    Mark Spano replied 15 years, 5 months ago 4 Members · 21 Replies
  • 21 Replies
  • Jeremy Garchow
    June 14, 2010 at 2:36 pm
    What is your frame offset set to in your prefs?
    What is your deck control set to in the capture preset?
    Have you calibrated the deck to fcp and vice-versa?
    Is the same deck whne laying off also being fed to the input of the Kona?
  • Mark Spano
    June 14, 2010 at 2:58 pm
    [Jeremy Garchow] “What is your frame offset set to in your prefs?”
    Set to 0 as per AJA.
    [Jeremy Garchow] “What is your deck control set to in the capture preset?”
    It was set to AJA KONA LH: 29.97 Sony A – been getting some better results due to another suggestion to try Sony B. Noting the only difference between the two is that the Capture Offset in Sony A is -1.5 and in Sony B is -2. I am now assuming that the Capture Offset is really a “TC Read Offset” and that the TC sense coming over 9-pin factors in both capture and edit to tape.
    [Jeremy Garchow] “Have you calibrated the deck to fcp and vice-versa?”
    I feel like I’ve done this a bunch of times with the A protocol – but since this problem is intermittent, I am never sure if it’s right.
    [Jeremy Garchow] “Is the same deck whne laying off also being fed to the input of the Kona?”
    Yes.
    I wish there was a clear explanation and setup procedure for using AJA’s cards in conjunction with decks. I am thankful to have other people on the net who have come across the same issues as I have and have also figured out workarounds, but these things should be explicit in the manual – specifically how to achieve perfect frame-accurate captures and edits to tape, and how to factor delay times for up/down/cross-conversions. I’ve done a lot of my own research into these areas and every now and then am thrown off by a frame or fractions of.
  • Jeremy Garchow
    June 14, 2010 at 4:51 pm
    [Mark Spano] “specifically how to achieve perfect frame-accurate captures and edits to tape, and how to factor delay times for up/down/cross-conversions.”
    Since there’s over a million combinations (format, frame rate, codec, environment, etc), this is pretty much futile. You will have to test your config and your setup and find the right one. If doing a conversion (up/down/cross) you can pretty much settle on one frame delay.
    [Mark Spano] “I feel like I’ve done this a bunch of times with the A protocol – but since this problem is intermittent, I am never sure if it’s right. “
    I’d suggest you read the manual in this regard as it really does have a very good explanation of this process. Now that Apple has made the manual available and searchable on the interwebs, here’s the page:
    https://documentation.apple.com/en/finalcutpro/usermanual/index.html#chapter=114%26section=4%26tasks=true
    Jeremy
  • Mark Spano
    June 14, 2010 at 5:30 pm
    Jeremy,
    I have read the manual top to bottom. It is still eluding me how to get the behavior to be consistent. I follow the procedures step by step to establish a capture offset with one deck. This is capturing a bunch of times off a striped tape with white pops/beeps at specific timecodes. Great, seems consistent at -2. Now I go to edit to tape some of the footage I just captured. Duplicate frames. I set the Playback Offset to zero (like the manual says) and try again. Count the number of duplicated frames (in this case, 2) and enter that in. Edit to tape again, great, it’s in on the right frame, no duplicate frames. But now, the audio comes in either one field or one frame late. NOT consistently. So here is the rub – there is no way to change audio/video playback offset independently. That, to me, makes Edit To Tape with this configuration unreliable. I would even not mind if the offset were consistently one value, I could factor it into my sequences. But since it’s off by fractions of a frame, and differently each time, it’s useless.
    [Jeremy Garchow] “If doing a conversion (up/down/cross) you can pretty much settle on one frame delay.”
    These are my results of my prior testing. I ran them by AJA and they confirmed that this is what I should be getting. It’s not consistent, and they agree with my findings. Also – NOT in the manuals…
    KONA 3 Output – Delay Compensation for Video Conversion
    When not performing any conversion on resolution or frame rate, the KONA 3 is frame accurate in edit to tape for video and audio.
    When upconverting (for example, 525i29.97 to 1080i29.97 – only resolution, not changing frame rate) the output from KONA 3 is frame accurate for audio and 1 frame late for video.
    To compensate for this, shift video in sequence earlier by one frame.
    When downconverting (for example, 1080i29.97 to 525i29.97 – only resolution, not changing frame rate) the output from KONA 3 is frame accurate for audio and 1 frame late for video.
    When converting (1080sf23.976 to 1080i29.97 – adding pulldown only, not changing resolution) the output from KONA 3 is frame accurate for both video and audio.
    When crossconverting (720p59.94 to 1080i29.97) the output from KONA 3 is frame accurate for video and audio is one field early in 29.97i.
    When downconverting (720p23.976 to 525i29.97) the output from KONA 3 is frame accurate for video and audio is one field early in 29.97i.
    When crossconverting (720p23.976 to 1080i29.97) the output from KONA 3 is frame accurate for video and audio is approximately .4 frame early in 29.97i.
    The only true solution to compensate for these types of conversions is to do a separate edit for video (at conversion) and audio (with no conversion), since audio can not easily be shifted accurately by less than a frame in FCP. Or open the audio track in Pro Tools and add the delay time to the beginning of the track, consolidate, and export, then import that into FCP and replace the audio in your sequence with your delay-compensated file.
  • Jeremy Garchow
    June 14, 2010 at 5:37 pm
    What does your timeline look like? Do you have any generators or slugs or open gaps where you are trying to assemble?
  • Mark Spano
    June 14, 2010 at 6:17 pm
    This one I’ve been testing with only has the clips I captured from tape. No generators, slugs, or gaps. Just solid media.
    Sequence: 1080i 59.94 (29.97 fps) Upper First
    1 video, 2 audio tracks
  • Jeremy Garchow
    June 14, 2010 at 6:20 pm
    OK, so try putting a second of a slug in front of your media and start the assemble in that slug.
  • Mark Spano
    June 14, 2010 at 10:04 pm
    Dropped a slug in, had same results. Doing insert edits, if that makes any difference. I started over again. After resetting the prefs and blowing away all of the custom easy setups, I started with a DVW-A500 and the KONA LHe. This was the resulting DCP:
    Then I had to set a different one for the SRW-5500:
    Then I had to set a different one for the SRW-5500 at 24p:
    It sort of makes sense to do this, but a really frustrating task nonetheless. Occasionally, as well, I would get differing landing points on tape for audio/video – I still haven’t found a solution for that, other than restart and sometimes it just fixes itself. I am always going to be suspect about editing to tape with these configs. I’m just not able to be 100% sure this’ll work every time because of the inconsistency. Is there still something I’m overlooking in the setup? I’m going to try in the next day or two to do this whole process over again with the KONA 3.
  • Mark Spano
    June 15, 2010 at 12:01 am
    Go figure – KONA 3 was the same setup for all three: -1.5 capture, +1 playback offset. This same setting on Friday didn’t work for me though, with duplicate frames and out-of-syncitude. It’s got me laying everything off with a flash/pop now so I can verify. Ugh – I am going to chalk it up to gremlins and call it a night.
  • Jeremy Garchow
    June 15, 2010 at 1:38 am
    Ah, the Quit and Go Home Early Method.
    Has worked for me many times. 😉
    Jeremy
Page 1 of 3
