Activity › Forums › AJA Video Systems › KOna3 Newbie Questions
Posted by Paul Burgess on April 28, 2009 at 4:31 pmI have a Kona3 with the breakout box,
I have updated the latest control panel and firmware from the Kona site.I am using FCP latest version.
I am trying to use the card to convert SD and some HDV video files on my discs to a standard HD format that is also stored on the hard disc.
It the moment I cannot even get the option of Macintosh Desktop in Control screen, not even greyed out.
I have a pile of SD tapes as well as HDV tapes from a Sony Z1. I now use the SonyEX1 and so want to work with all the sources in the same format.
Has anyone any idea what I am doing wrong?
Paul
Jesse Green replied 17 years, 4 months ago 7 Members · 15 Replies -
Jeremy Garchow
April 28, 2009 at 5:19 pmSimply select the appropriate HD easy setup from within FCP, then go to your Control Panel. Set your primary format to 1080i and your secondary format to 525i. You should then see an up convert signal on the appropriate input. GO back to FCP and capture.
Jeremy
Paul Burgess
April 28, 2009 at 7:47 pmThank you.
I only have firwire to input the hdv footage -so in effect I am reading from disc not capturing.I do not have an SDI output from the Z1.
Paul
Jeremy Garchow
April 28, 2009 at 7:54 pm[Paul Burgess] “I only have firwire to input the hdv footage -so in effect I am reading from disc not capturing. “
Woops, wrong post on that first one.
You need an AJA A/D convert to get your analog HD and audio to HDSDI w/embedded aduio. The HD10AVA will work for you.
Jeremy
Paul Burgess
April 28, 2009 at 8:54 pmOk – so the HD10AVA takes my component out of the Z1 and converts to SDI to input to the Kona 3 – then with FXP I can capture the converted input to a disc on the Mac – right?I do not need to go out through the Kona 3 …. correct?
Paul
Ted Joyce
April 28, 2009 at 9:37 pmCan’t one just use use your Mac’s firewire port to input HDV from your Sony Z1 camera? (the K3 doesn’t have analog HD inputs) I’m getting ready to capture some Z1 HDV & hope to do that. Then drop the footage into a timeline to covert.
Paul Burgess
April 28, 2009 at 9:41 pmYes I can do that but that is not using the higher quality conversion available with the Kona 3…. right?
I understand now that the Kona 3 only converts on capture ….. that is what I now understand anyway.
So I now have to buy a HD10AVA which here in the UK is about $1200 USA.
Paul
Jeremy Garchow
April 28, 2009 at 10:02 pm[Paul Burgess] “then with FXP I can capture the converted input to a disc on the Mac – right?I do not need to go out through the Kona 3 …. correct? “
I am not following what you are saying here.
You take the AVA and that will basically turn your analog deck into an HDSDI with embedded audio deck.
You capture using that via the Kona3.
Make sense? THis is way you can then upconvert whatever you need to the same codec as your captured HDV footage. The EX1 you will have to transcode in software. I’d suggest using ProRes for your unified capture and edit codec.
Making more sense?
Also, you might want to consider the new LHi which has all of these features in one card for $1495 US. If you need to keep your Kona 3, then the AVA is for you. Either way, you won’t go wrong.
Jeremy
Paul Burgess
April 28, 2009 at 11:43 pmWhat I have been trying to do is use the Kona 3 to up convert files already captured to my hard disc,
That I now understand is not possible because the Kona3 only converts on capture – is that right?
Sp given that is the case, as you say, I have to buy an AVA card to turn my Z1m whih I use as the deck in this case, into an SDI input into the Kona 3 – correct?
Then FCP will capture the converted video so that it now sits on the hard disc ready for FCP editing. Correct?
I have no problem with the EX1 files.
I was going wrong in thinking that the Kona 3 could do the conversion without capturing.
It does not make any sense for me to spend a few more thousand dollars on the LHi as its cheaper to buy the AVAm I already have the Kona3…. agreed?
Thank you for your tolerance in answering these basic questions.
Paul
Gary Adcock
April 29, 2009 at 12:07 am[Paul Burgess] ” I now understand is not possible because the Kona3 only converts on capture – is that right? “
Correct, the Kona3 is a video capture card- it handles these functions while in operation.
[Paul Burgess] “It does not make any sense for me to spend a few more thousand dollars on the LHi as its cheaper to buy the AVAm I already have the Kona3…. agreed? “
Paul the AVA10HD is a converter that will allow you to capture from analog audio and video sources using the Kona3 you already have.
gary adcock
Studio37
HD & Film Consultation
Post and Production WorkflowsInside look at the IoHD
https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php -
Paul Burgess
April 29, 2009 at 6:12 amThank you – it is clear now.
One more question.
Here in the UK there is not much difference in price between purchasing the AVA and purchasing the Matrox MX02, which seems to have all the options and even frame rate conversion plus portability.Do you know if there is a difference in the quality of the conversion between the Kona 3 using the AVA to get and SDI input and the Matrox MX02?
Currently I am tempted to take the Matrox MX02 route.
Paul
