Activity Forums AJA Video Systems Kona3 Issues
  • Walter Biscardi
    July 5, 2006 at 12:16 am
    [Oliver Peters] “If you are recording 36fps intended to be played at 24fps, you’d still need the FCP plug-in and work only in DVCPRO HD.”
    No, you can capture directly any off-speed footage, however, FCP will not capture your entire clip correctly, so it’s easier to use the FRC after capture. See the earlier posts for an explanation of what happens when FCP tries to capture off speed footage when you’re trying to do a Batch Capture.
    Walter Biscardi, Jr.
Page 2 of 2
