Kona3 Issues
Hello all,
I have been testing my new Kona3 card and have been experiencing some issues:
1) VFR – I remember reading a post about this in the VariCam Cow forum within my thread “Variable Framerates”. It seems when the card is used to capture media at off-speeds it only records the length of time in the timecode, not the entire tape. For instance, we recorded off-speed and I captured directly from the camera using capture now; in order to get the whole slo-mo scene, I would have to leave the capture running for an additional minute after the scene was finished. This is because the card brings the media in and converts it to slo-mo on the fly. We captured to tape afterward, and the same thing happened, I could only get the length of TIME we had recorded in slo-mo, if we captured it via firewire without the card, this would give us the whole tape and then it could be converted using Panasonic’s FRC plug-in for Final Cut Pro. This all makes sense in how and why it is happening, but there must be a workaround via the card. Right now, it seems the camera operator would have to continue recording for awhile after the off-speed scene if finished.
2) Timecode – (this may be more of a Final Cut Pro question) Using the VariCam as a deck, I could not see timecode reading through my Log & Capture window. The Kona Control Panel shows RP-188 Timecode and reads it perfectly from the camera, however this timecode does not read or record into FCP for capture. Am I missing something, some step?
Any help is VERY MUCH appreciated! We have a project coming up with the VariCam and we are testing for issues between it and the Kona3 card.
Thanks In Advance!
~Athen
