Activity Forums AJA Video Systems Kona2 & audio crackling
  • Kona2 & audio crackling
    Posted by Mark Maness on August 25, 2005 at 6:14 pm
    I’m having a strange problem here. Every once in a while when I stop the CTI on the timeline and start it up again, the audio makes a crackling noise like distortion. But if I stop again and start it up again, its fine. I have the 1.12 drivers installed. Its not a real problem but its very annoying.
    _______________________________
    Wayne Carey
    Schazam Productions
    Shawn Yashar replied 21 years ago 6 Members · 6 Replies
  • Greg Jones
    August 25, 2005 at 6:16 pm
    I have the same problem. If I go to the Kona Control Panel and switch the genlock from video in to free run it seems to help the problem.
    Greg Jones
    D7,Inc.
    Orlando,Fl.
  • Bob Zelin
    August 26, 2005 at 2:31 am
    Greg is correct – I don’t know why – it’s almost like a bug – the Kona 2 will “for some reason” – and there must be a reason – switch to Reference – Video In – by itself. Switch it to external ref (if you have an external ref) or Free Run, and your crackle will go away.
    Bob Zelin
  • Craig Ernst
    August 29, 2005 at 8:27 am
    HI,
    Same problem here.
    Dual 2.5 G5
    OSX.4.2
    Kona 2 (1.1.2)
    FCP5.02
    AttoUL4D
    QT7.0.1
    Craig
  • Berenger Capmany
    August 31, 2005 at 9:29 am
    Same problem here also (PAL)
    I have to say that I have heard the same crackling noise in the IO BOX LD .. it was solved with firmware updates..
    cheers!
  • Mark Maness
    September 1, 2005 at 5:25 pm
    After playing with it for the past few days. I noticed that the sync on mine is already set to Free Run and I still get the crackling noise. I don’t know but its annoying when you have a client in house and have to appoligize for the noise. Usually have to just stop my program, then start playing it again and its fine. Its weird!
    Wayne Carey
    Schazam Productions
  • Shawn Yashar
    September 6, 2005 at 10:33 pm
    Interestingly enough I had this same problem on the BlackMagic Extreme as well. Never was resolved…
    I wonder if it is some kind of FCP issue.
