Activity Forums AJA Video Systems Kona2 and DVCPRO HD 1080/50i & 1080/25p
  • Kona2 and DVCPRO HD 1080/50i & 1080/25p
    Posted by Henning on August 5, 2005 at 6:43 am
    Hi there,
    we own a Pana AJ-HDX400 (Yes there are more DVCPRO HD Camcorders than Varicams)and a AJ-HD1200 with IEEE1394 and HD-SDI. The HDX400 records in 1080/25p or 1080/50i. Can anyone tell me how to setup the Kona2 / FCPHD to Work with this HD-material in a “PAL” enviroment?
    Sorry for my poor English!
    Henning from Germany
    Henning G
    Itamar Kool replied 21 years, 1 month ago 2 Members · 1 Reply
  • Itamar Kool
    August 6, 2005 at 8:16 am
    I posted this asnwer a bout a week ago. Got this receipt from AJA for a 720p set up. Just replace the 720p for 1080i. Take care to shoot at the same frame rate that you use for capture.
    Works fine here.
    Here are the steps to create a 720p 25 easy setup.
    1) Setup FCP with a Kona 2 720p 23.98 easy setup.
    a) Go to Easy setup menu ( ).
    b) Make sure the SHOW ALL checkbox is checked.
    c) Select one if the Kona 2 720p 23.98 easy setups (uncompressed or
    DVCpro HD – your choice).
    2) Create a varicam 720p 25 capture preset.
    a) Go to FCP audio video settings -> capture presets (tab).
    b) Click on : Automatically makes a copy and puts you in
    the preset editor.
    c) Rename capture preset to Kona 2 varicam 720p 25.
    d) Change FPS from 23.98 to 25.
    e) Exit.
    3) Create a varicam 720p 25 sequence preset.
    a) Go to FCP audio video settings -> sequence presets (tab).
    the preset editor.
    c) Rename sequence preset to varicam 720p 25.
    e) Exit.
    4) Go to FCP audio video settings -> Summary and click on Setup>. Name it Kona varicam 720p 25 “codec name”. This easy setup is based
    on the new capture preset and sequence preset you created in steps 2 and 3.
    Note: playback remains at 720p 59.94.
    Kool En De Anderen
    dual 1.8 gig G5/Mac OS 10.3.9/Kona 2/Hugh 800 G diskarray, fibrechannel/FCP 5.02/AE 6.5 Pro
    http://www.koolendeanderen.nl
