Activity Forums AJA Video Systems Kona to External Monitor
  • Kona to External Monitor
    Posted by Dave Presley on January 22, 2009 at 2:33 pm
    I just got a new Kona Card installed into our editing system and we are having a couple of problems. I try to bring a 720/30p P2 media into FCP and it plays on the timeline fine, it does not play out to our external monitor. I have been through the Aja Control Panel and changed the outputs to several different things, is there something I am missing? or is this an FCP problem. I will post a different thread in the FCP forum. If anybody could shed some light onto this problem that would be great!
    Dave Presley replied 17 years, 7 months ago 2 Members · 13 Replies
  • 13 Replies
  • Jeremy Garchow
    January 22, 2009 at 2:59 pm
    Set your video output to 720p59.94 8 bit.
    Jeremy
  • Dave Presley
    January 22, 2009 at 3:58 pm
    I do that I set final cut to that setting and then bring my footage to the timeline, I get an error:
    For best performance your sequence and external video should be set to the format of the clips you are editing.
    I click Yes and the viewer in FCP shows the footage fine, but my external monitor that is running through the Kona card does not, It just tells me there is no sync and every second the clip flashes onto the screen.
    Any suggestons?
  • Jeremy Garchow
    January 22, 2009 at 6:38 pm
    Okay.
    • Hit control-q to bring up the easy setups.
    • Choose the AJA Kona DVCPro HD 23.98 VFR setting.
    • Make a new sequence.
    • Hit command-zero with that sequence selected to bring up the sequence setting. Change the frame rate to 29.97.
    • Add a clip to the timeline and you should get no error.
    • Edit.
    Jeremy
  • Dave Presley
    January 22, 2009 at 8:10 pm
    I dont have that setting in my FCP settings?? have many different Konas but Kona DCPRO HD isnt one of them.
  • Jeremy Garchow
    January 22, 2009 at 8:18 pm
    You must not be looking in the right place.
    It looks like this:
  • Dave Presley
    January 22, 2009 at 8:50 pm
    I do not have AJA KONA 3, I have AJA KONA LH…the only DVC PRO HD options are
    LH – 720p 59.94 DCVproHD
    LH- 720p 25 DVCpro HD VFR
    LH – 1080 psf DVCpro HD VFR
  • Jeremy Garchow
    January 22, 2009 at 8:55 pm
    It’s okay. Yours will just say Kona LH instead of Kona 3.
    Make sure that you put the frame rate to ‘all rates’ in the top right hand corner.
    Jeremy
  • Dave Presley
    January 22, 2009 at 9:02 pm
    It kinda works!!!! I get my video on my external monitor but the monitor keeps dipping to black every now and again, could that be a connection problem or a setting problem? Its alot better than what I had before but still there is no consistent image on my external monitor, it blinks to black.
  • Dave Presley
    January 22, 2009 at 9:04 pm
    It also flashes the same error message, i just pressed yes and thats when the video came on screen.
  • Jeremy Garchow
    [Dave Presley] ” my video on my external monitor but the monitor keeps dipping to black every now and again, could that be a connection problem or a setting problem?”
    What kind of monitor do you have and what kind of connection?
