Activity › Forums › AJA Video Systems › Kona project on non-Kona G5
  • Kona project on non-Kona G5
    Posted by Mjworks on July 18, 2006 at 2:11 am
    Question, if I connect a media drive filled with Kona 8 bit footage to a seperate G5 with FCP 5.1 (without Kona) will I be able to edit that footage?
    I will be authoring a DVD (DVD Studio Pro) with this footage and might need to run FCP also.
    Max T.
    MJWorks L.L.C
    Mjworks replied 20 years, 2 months ago 3 Members · 3 Replies
  • Walter Biscardi
    July 18, 2006 at 11:03 am
    [MJWorks] “Question, if I connect a media drive filled with Kona 8 bit footage to a seperate G5 with FCP 5.1 (without Kona) will I be able to edit that footage?”
    Yes, the Kona is using Apple’s 8bit uncompressed codec.
    Walter Biscardi, Jr.
  • Andy Edwards
    July 18, 2006 at 4:42 pm
    I’m doing this right now on a 1 hour documentary. The editor out of state sent the project file, video, audio, graphics etc. on Firewire drives. I did have to reconnect most of the media as it pointed to his raid which is named differently then mine. I was able to open up his Kona base project just fine. The render files were not there, so I had to re-render all the layers of audio, but it played back fine right after the full render.
    Andy
  • Mjworks
    July 18, 2006 at 4:44 pm
    Thanks Andy
    Sounds like I should not have any problems.
