Activity Forums AJA Video Systems Kona LHi – HDMI output stopped working
  • Kona LHi – HDMI output stopped working
    Posted by Krzysztof Kalukin on June 24, 2009 at 11:12 am
    Hello,
    Yesterday I had to disconnect my HDMI monitor which was used for HD monitoring. When I reconnected it, I can only see “No signal” message. Monitor is OK, because it works with other sources. Kona outputs analog signal without any problems, but HDMI does not work. I tried to reset, change settings, etc – no effects. What can be wrong? What should I do?
    Please help.
    Krzysztof
    Krzysztof Kalukin replied 17 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
