Activity Forums AJA Video Systems Kona LHi Component Capture Issue
  • Kona LHi Component Capture Issue
    Posted by Matt Dufilho on June 4, 2011 at 6:56 pm
    Good morning,
    I’m sure you all will have a simple fix, but I’m trying to capture a DVD via component inputs through my Kona LHi in Final Cut.
    I’ve verified (on a separate monitor) that I’m getting a good signal through the DVD player and cables.
    My AJA control panel is set for analog input, although it is displaying a 1080i30 signal. Is this part of the issue?
    I’ve tried to set my FCP capture settings for 525 29.97 Prores, but all I get (on any capture setting) is multicolored static and roll on the screen.
    What am I missing, guys?
    Thanks.
    Matt Dufilho replied 15 years, 3 months ago 1 Member · 1 Reply
  • Matt Dufilho
    June 4, 2011 at 9:12 pm
    OK, just solved the issue. Switched DVD players.
    The previous one was a Magnavox DVD recorder. If output was set to progressive scan, would that have an effect? I’ll do some testing.
    Sorry for the false alarm.
