Activity Forums AJA Video Systems Kona LHe Monitor
  • Kona LHe Monitor
    Posted by Daniel Tuffin on January 16, 2006 at 2:58 pm
    Hi All, i notice that the Kona LHe KL-Box has component & uses one of the components as a composite. If i were to split the Y/Composite could i then take the component signal to me deck for mastering & then my composite signal to a monitor. Are they all live, or is it all switchable via the control panel? I’m trying to come up with a way of mastering, but also being able to monitor to a composite only monitor.
    Thanks for you help
    Christopher Tay replied 20 years, 7 months ago 2 Members · 1 Reply
  • Christopher Tay
    January 16, 2006 at 5:36 pm
    The Component and Composite/Y-C are switchable from the AJA Control Panel so you can’t have all active at the same time.
    You can get the AJA D10CE and convert the 2nd SDI output to Component AND Composite outputs. Or you can just get the AJA D4E and convert the 2nd SDI output to 2 x Composite outputs and use the LHe for the Component output.
    -chrispy
