Activity Forums AJA Video Systems Kona LHe is not giving an image on the HD video monitor
  • Kona LHe is not giving an image on the HD video monitor
    Posted by Core Van der hoeven on September 4, 2008 at 4:24 pm
    I definitely must do something wrong, but I can’t get the Kona to work; I just get green lines on my HD video monitor
    I work in HDV, analog output in the aja controlpanel is on component SMPT/EBU 1080i25
    SDI out gives the same kind of image on the monitor
    I’m on the latest drivers (6)
    Maybe someone here has an idea what I’m doing wrong you could make me happy
    thanks,
    Core
    Jeremy Garchow replied 18 years ago 2 Members · 6 Replies
  • Jeremy Garchow
    September 4, 2008 at 5:51 pm
    Have you setup the proper easy setup within FCP?
    Did you uninstall and reinstal the drivers?
    If you go into the Kona control panel and choose the control tab, set the default video output to Test Pattern > Color bars – 75%, do you see bars?
    Jeremy
  • Core Van der hoeven
    September 4, 2008 at 7:03 pm
    Thanks for your reply,
    Yes I do see the test pattern, the color bars
    I didn’t uninstall and reinstal the drivers, can try that
    Core
  • Jeremy Garchow
    September 4, 2008 at 7:09 pm
    Okay, if you see the test pattern, then open up FCP and choose the proper easy setup by hitting control-q
    Jeremy
    September 4, 2008 at 7:16 pm
    Ok try that first thing in the morning
    thanks, Core
    September 4, 2008 at 7:32 pm
    Although I can’t imagine something is wrong there if the external video is set to Kona LHe 1920 1080i 8bit and sequence preset is set to Kona LHe prores 422 1920 1080i
    but I’ll check this tomorrow
    Core
  • Jeremy Garchow
    September 4, 2008 at 7:38 pm
    [Core van der Hoeven] “Although I can’t imagine something is wrong there if the external video is set to Kona LHe 1920 1080i 8bit and sequence preset is set to Kona LHe prores 422 1920 1080i “
    Yes it is. ProRes is 10bit, your video output is set to 8 bit. Therein lies the problem.
    Jeremy
