Activity › Forums › AJA Video Systems › KONA LHe hanging up new MAC PRO 4,1
  • KONA LHe hanging up new MAC PRO 4,1
    Posted by Gene Bauer on May 18, 2009 at 3:07 pm
    I have (2)new out of the box Mac Pro 2.93 ghz Quad Core Intel Xenon that are hanging up on bootup. If I take the KONA LHe cards out they boot fine. Anyone else seen this? Machine came preloaded from the reseller with Adobe CS4 and the KONA card installed. We’ll probably wipe it clean and start a fresh install of everything…any advice on the order of installation, partitioning would be much appreciated…we have Final Cut Studio2 and Adobe CS4 going in with a KONA LHe.
    Martin Roe replied 17 years, 4 months ago 4 Members · 5 Replies
  • Gary Adcock
    May 18, 2009 at 9:43 pm
    [Gene Bauer] “I have (2)new out of the box Mac Pro 2.93 ghz Quad Core Intel Xenon that are hanging up on bootup. If I take the KONA LHe cards out they boot fine. Anyone else seen this? Machine came preloaded from the reselle”
    Gene
    shoot the reseller for being lazy and not testing the machines before delivering them to you, I hope it was a local guy you can drag into your office.
    you will need to try manually updating the the firmware on the card.
    the firmware updater is in the Applications > AJA Utilities Folder.
    boot into Safe Mode to get access to the card (hold down the shift key on startup)
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Check out
    https://www.aja.com/kiprotour/
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Kent Stipp
    May 19, 2009 at 9:10 pm
    Gene,
    I agree with Gary. Additionally what slot did they put your card in. I have heard of this problem. You mentioned partioning. I do not see a reason for that no need. But the reseller should have sufficently tested the machine before delivery.
    Kent Stipp
    Life Begins at 155mph
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
  • Martin Roe
    June 1, 2009 at 7:56 am
    i have been having this exact same problem with my kona 3 in a brand new mac.
    It is inconsistent. If i remove the card and reinstall final cut pro, the machine will reboot and I can use the card. However if i attempt to restart my machine after this, it hangs blue on the screen.
    I thought it might be damage to the card (it is second hand) and was going to send it to AJA under warranty tomorrow, but I think I might try the firmware now instead.
    M
  • Gary Adcock
    June 1, 2009 at 12:29 pm
    [Martin Roe] “I thought it might be damage to the card (it is second hand) and was going to send it to AJA under warranty tomorrow, but I think I might try the firmware now instead. “
    that will fix it…
    gary adcock
    Studio37
    Check out
  • Martin Roe
    June 1, 2009 at 9:25 pm
    And it did 🙂
