Activity Forums AJA Video Systems Kona Lhe- Edit to Tape to DSR1500AP via SDI problem
  • Kona Lhe- Edit to Tape to DSR1500AP via SDI problem
    Posted by Eugene Constable on October 31, 2008 at 3:18 pm
    Am trying to do an insert edit from Final Cut to a pre-striped DVCAM tape (using DSR1500AP)
    I want to go out of my kona LHe card into the deck via SDI
    When I perform Insert Edit, final cut starts the process fine, but soon my DSR deck says:
    “Input video signal does not synchronize with reference video signal.
    Use common ref signal.”
    It then stops recording.
    I simply have the SDI Ins/Outs from the Kona LHe cabled to the respective INs\OUTs on the deck…
    A colleague tells me that SDI carries its own sync signal so no need to get a blackburst generator, is this true? If so how do I lay stuf off to my DSR using edit to tape and avoid this “not synchronize” message?
    Eugene
    Bob Zelin replied 17 years, 6 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    October 31, 2008 at 5:53 pm
    [Eugene Constable] “A colleague tells me that SDI carries its own sync signal so no need to get a blackburst generator, is this true?”
    Yes and no. Your deck has to be able to select the incoming video signal as sync. If not, you need a blackburst generator and you will ser your deck and KOna to external reference.
    Jeremy
  • Bob Zelin
    November 1, 2008 at 4:42 pm
    where is my gun !
    you write –
    REPLY – you know the answer – you stated it in your post – the answer is on the screen right in front of you. Stop listening to you colleague.
    Bob Zelin
