Activity › Forums › AJA Video Systems › Kona lhe: dvcproHD out
  • Kona lhe: dvcproHD out
    Posted by Tommaso Cicognani on May 7, 2007 at 8:03 am
    hi all,
    I started editing footage 720p in FCP in5.1 timeline(material shooted with the Hvx200). I set the timeline setting on dvcpro hd720 and all is OK.
    Then I use the Aja kona LHE to send my video out to an external boardcast video(SD)to make color correction but I can see only still frames and not video. why? Should I set FCP in a diferent manner?
    Walter Biscardi replied 19 years, 4 months ago 5 Members · 9 Replies
  • 9 Replies
  • Walter Biscardi
    May 7, 2007 at 11:26 am
    If you have an SD monitor, you need to set the Kona card to down-convert the signal. You do this in the Kona Control Panel, NOT Final Cut Pro. Look at the documentation that came with the Kona card as this explains very nicely how to set your outputs up to downconvert.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Christopher Tay
    May 7, 2007 at 3:27 pm
    What is the Video Playback in FCP (Audio/Video Setting) set to ? It must be the same 720 format that you have set for your timeline. And set the Kona Control Panel to downconvert to SD.
    What frame rate is this 720 timeline running coz downconvert doesn’t work on every frame rate.
    -chrispy
  • Walter Biscardi
    May 7, 2007 at 3:33 pm
    [chrispy] ”
    What frame rate is this 720 timeline running coz downconvert doesn’t work on every frame rate.”
    I’ve never had it not work here. 720 is always played out at 59.94 regardless of what the timeline is set to. I’ve worked in 23.98, 25, 30 and 59.94 and all of them play out / downconvert just fine because the output from the system is always 59.94.
  • Tommaso Cicognani
    May 7, 2007 at 4:27 pm
    thnak for your answers but the problem persist. I set the Kona (in its control panel): primary format: 720p50
    secondary (converted) format: 625i25
    In analog out I set:
    anologue output fomat: secondary 625i25
    and in the control panel appear the icon of downconversion.
    In FCP the timeline is set in DvcproHd:
    frame size: HD (960×720)
    Pixel ascpect ratio960x720
    etc..
    In the video out panel (under view,videoplayback..)I set
    Aja kona 720P50 8bit (1280×720)(I tried to put also Aja Kona 625i25…but the problem persist).
    Thank you for your patience and I ask your pardon if these aswers are so stupid.
    thanks
    Tom
  • Gerry Curtis
    May 7, 2007 at 5:42 pm
    Hi there,
    I’m having the same problem with a Kona 2 and 720p25. It plays on my HD monitor but won’t downconvert to my SD monitor under the correct settings in FCP and Kona control panel.
    The Kona rep said it was an Apple glitch that they’re working on fixing. The workaround he gave me was to copy the sequence to an uncompressed 8 bit 720p25 timeline and use the 720p 8 bit Kona Video out setting. Very slow and lots of rendering involved but it plays in SD now.
    Also a huge hassle to get from the P2 cards into fcp (compared to NTSC) at 25fps but that’s a whole other story.
    Gerry
  • Christopher Wright
    May 7, 2007 at 8:16 pm
    Yes it does seem like Apple trouble in PAL land once again!
  • Christopher Tay
    May 8, 2007 at 4:19 am
    I think it’s because FCP doesn’t support 720p25 yet.
    -chrispy
  • Tommaso Cicognani
    May 8, 2007 at 12:11 pm
    I believed that with the version 5.0.1 Apple would have solved that issue…in my opinion its a shame that Apple havn’t yet fixed this problem
  • Walter Biscardi
    May 8, 2007 at 12:17 pm
    [tommaso79] “I believed that with the version 5.0.1 Apple would have solved that issue…in my opinion its a shame that Apple havn’t yet fixed this problem”
    They did, it’s not out yet. It’s call Final Cut Pro 6. From the Tech Specs:
    HD at 1080i 50/60, 1080p 23.98/24/25, and 720p 23.98/25/30/60
