Activity › Forums › AJA Video Systems › Kona LHe: Downconvert on capture?
  • Kona LHe: Downconvert on capture?
    Posted by Erik Lindahl on May 4, 2006 at 11:38 am
    I’ve got a simple question:
    Does the Kona LHe do downconverting to SD on capture?
    Also, does anyone have any experiance comparing IMX recored material to HDCAM materil down-converted.
    Erik Lindahl replied 20 years, 5 months ago 3 Members · 3 Replies
  • Walter Biscardi
    May 4, 2006 at 1:07 pm
    Yep, you set this up in the AJA Control Panel. In FCP, you simply set up to capture at whatever SD codec you want to capture to (DV, DV50, 8 / 10bit).
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Christopher Tay
    May 5, 2006 at 8:17 am
    In the AJA control panel, set the format to the input signal and in FCP, choose your SD capture preset and you’re all set. You may also want to check the downconvert setting in the AJA control panel if you are using an SD video monitor.
    -chrispy
  • Erik Lindahl
    May 5, 2006 at 10:31 am
    Great great… Might be an option to do this then. Thanks!
