Activity › Forums › AJA Video Systems › Kona LHe and Xena LHe the same?
  • Kona LHe and Xena LHe the same?
    Posted by Craig Meadows on June 16, 2009 at 9:55 pm
    Are the Kona LHe and Xena LHe the same cards physically? With the only difference being the drivers required for PC or Mac? I recall seeing something a while back in the support area on the Aja site about this but now can’t find it. Seems there was a licensing agreement that had expired and you could now run a Kona as a Xena in a PC.
    I have an older Kona LHe and want to try it in a qualified PC.
    Tim Kolb replied 17 years, 3 months ago 4 Members · 3 Replies
  • Bram Tulloch
    June 17, 2009 at 1:19 am
    I know that the Xena2k and the Kona3 are exactly the same.
    I’m using a “Kona3” as a Xena2k right now.
    I would assume it would be the same for the LHe.
  • Christian Urbanski
    June 17, 2009 at 9:03 am
    we´ve installed a Mac pro (intel) + a aja xena lhe with bootcamp,and in macos it works with final cut like a kona amd in windows xp it works like a xena lhe under liquid chrome / adobe cs 3.works fine.
    Only need the driver for each S.o.
  • Tim Kolb
    June 23, 2009 at 8:45 pm
    As has been stated, the Kona/Xena physical part is the same.
    Kona LH/Lhe= Xena LH/LHe
    Kona LHi = Xena LHi
    Kona 3 = Xena 2K
    …and note that technically they aren’t -operating system- specific. They’re -application- specific. Kona is for FCP and Xena is for PPro/Vegas/et al. PPro on Mac OS needs a Xena (or technically Xena drivers).
    TimK,
    Director, Consultant
    Kolb Productions,
