Activity › Forums › AJA Video Systems › Kona LH – Will this do the job for me?
  • Kona LH – Will this do the job for me?
    Posted by Martin Phillips on October 16, 2006 at 12:33 pm
    Hi, I am on a G5 dual 2Ghz and looking to find a card which will allow me to work with Digi Beta, HDV, and P2 (DVCPRO HD), XDCAM and HDCAM if I need to. I want to be able to monitor via component to my SD monitor (I can’t stretch to a HD one yet!) I tried a card previously and had a lot of problems with the downconversion quality from P2 / DVCPRO HD footage. Will the Kona LH do the job well? I want to output projects onto Digi Beta so downconversion quality is essential.
    Thanks, Martin.
    Walter Biscardi replied 19 years, 11 months ago 4 Members · 4 Replies
  • Dan Brockett
    October 16, 2006 at 7:34 pm
    Hi:
    Sounds like the LH will do what you need as long as you are using all of those individual formats in their own projects. If you need to used SD footage in an HD project, you need the Kona 2 or 3, not the LH.
    I have the Kona 3 and it is heaven, a great tool that is intuitive, flexible and easy to use. Aja rocks!
    Dan
    Providing value added material to all of your favorite DVDs
  • Walter Biscardi
    October 17, 2006 at 12:12 am
    LH sounds like the card that will do what you need.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Vmalmgren
    October 20, 2006 at 2:02 am
    Hi: I have a similar question about the KONA LHe. Can I use it to ingest DVCPROHD and XDCAM HD material and edit both sources in the same FCP timeline?
  • Walter Biscardi
    October 20, 2006 at 2:46 am
    [vmalmgren] “Can I use it to ingest DVCPROHD and XDCAM HD material and edit both sources in the same FCP timeline?”
    You can’t mix formats on the same timeline in realtime. You use the Kona to convert your XDCAM material to DVCPro HD.
