Activity › Forums › AJA Video Systems › Kona Lh sync problem after 20mins ingest
  • Kona Lh sync problem after 20mins ingest
    Posted by John Pham on April 10, 2010 at 1:34 am
    Hello everyone, I have Kona LH in my XServe to capture live feed. The issue started after twenty minutes of caputering, then I would have a Frezzed frame and then the audio and the video get out of sync. Anyone here experienced that? or what could be the cause? Thanks
    John
    John Pham replied 16 years, 5 months ago 2 Members · 4 Replies
  • Arnie Schlissel
    April 10, 2010 at 3:37 pm
    Sounds like dropped frames. What kind of drive system are you capturing to?
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • John Pham
    April 11, 2010 at 8:28 pm
    I’m ingesting into my XRAID, could it be my Raid is bad?
  • Arnie Schlissel
    April 13, 2010 at 4:19 am
    What format of video are you digitizing? What speed is your RAID running at. Use the Kona system test program to test your drive speed. Also, how is the RAID formatted? For video it should probably be RAID 5 or RAID 0.
    Arnie
  • John Pham
    April 15, 2010 at 2:01 am
    Hi Arnie,
    I’m capturing it DV NTSC, i did a test for 720×486 8bit and the result for write is 267 MB/s, read 239 MB/s. I right clicked and got the Raid format as Mac OS Extended (Journaled).
