Activity Forums AJA Video Systems Kona LH component out problem!!
  • Kona LH component out problem!!
    Posted by Charlie Breguet on June 15, 2007 at 3:56 am
    Hi all, just was wondering if anybody has had a similar problem with their Kona LH…
    system- FCP 5.1.4/OSX 10.4/4gb ram/MAC G5 dual-PCIx
    problem- I am printing/mastering SD timline to Beta SP UVW 1800 via component and after making several successful beta masters I now have a scrambled component output that I can’t correct. I’ve tried rebooting, shutting down, repairing permissions etc…I did try patching the FCP component directly to the monitor via component to make sure it wasn’t my Beta deck.
    Should I re-seat the card or is there something else I should do?
    Much appreciated!
    Charlie
    Charlie Breguet replied 19 years, 3 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    June 15, 2007 at 4:01 am
    Check your Kona control panel and make sure that you are in fact set to component and not composite + y/c. Reset your AJA easy setup.
    Jeremy
  • Charlie Breguet
    June 15, 2007 at 11:57 am
    Hi Jeremy, I did check my control panel last night and it is set to component. I am going to reseat the board this morning and I’ll reset the easy setup.
    Thanks! Charlie
  • Arnie Schlissel
    June 15, 2007 at 2:06 pm
    While you’re at it, check your cabling to make sure it hasn’t come loose. If you have another component cable, swap it out.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Charlie Breguet
    June 15, 2007 at 5:48 pm
    Thanks for your help. Aja support emailed me today and suggested I trash preferences…I finally got around to it..working like a charm.
    Thanks! Charlie
