Activity › Forums › AJA Video Systems › Kona LH audio dropout
  • Kona LH audio dropout
    Posted by Shane Ross on November 10, 2006 at 6:13 am
    I just received a Kona LH and dropped it into my Dual 2Ghz G5 (PCI-X)…well, OK, I carefully installed it into my G5. Then I connected HD SDI out to my HD monitor…and it looks great. But when I take the XLR outputs and connect them to the balanced IN ports on my Tascam FW-1082 mixer, and play the timeline, I will get occasional and regular dropouts in audio. The VU meters stay steady, it only happens on the mixer end. I connect the speaker out of the G5 to the mixer and the audio sounds fine…no dropouts.
    Anyone experience this…and solve it?
    Shane
    Littlefrog Post
    http://www.lfhd.net
    Shane Ross replied 19 years, 10 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    November 10, 2006 at 10:44 pm
    SO it sounds like it’s a problem with your tascam or your setup.
    I just looked at the Tascam and it appears those XLR inputs are mic level. Could that be your problem? if you hook up your KOna card to anything else (like a deck), do you still get the same dropouts?
    Are you sure you have hooked up the analog outputs and not the digital?
    Most recent drivers/firmware from the AJA site?
    Jeremy
  • Shane Ross
    November 12, 2006 at 3:16 am
    I’ll look again. I am currently working 12 hours 6 days a week so I have little time to devote to my home system. But those are all good things to check out.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeremy Garchow
    November 12, 2006 at 4:18 pm
    Good luck, Shane. I know that schedule you are on very well.
    Jeremy
  • Shane Ross
    November 13, 2006 at 8:29 am
    Hmmm…they are the ANALOG OUTs…so.
    I will have to look into this later.
    Shane
    Littlefrog Post
    http://www.lfhd.net
